BigRand
- 2,181
- 32
- Nov 17, 2004
Toronto,
Well I got my emange to work today....got it on the dyno....thing runs great.....I only put down 200whp because some how my fuel pump from my star kit got put in instead of my 255. Go figure......so now I'm gonna wait for some more cash so I can run some 550cc injectors and go from there.
Emange and e01 work great together....the response is awesome....and kicks in right away....You can also get it to where it holds the wastegate shut for a small amount of time and then let all the pressure out at once, to try to eliminate turbo lag.
Fuel map stuff is easy on this...and nice to operate.
Using the msd box that I have....we pulled a lot of timing to start with. (about 16 degreees) and that made it way easy to adjust the fuel then bring it back in.
I had it going really good at 12psi....making close to 240whp...but the only thing was the fuel pump and injectors couldn't keep up with the boost at the last 1000rpm's.
I'll be doing a more complete update of the process and settings pretty soon.
. I need to know these things as well.. .
