Please Support RTM Racing
Rear tires bigger than my front!
jibberishballr
477
3
Aug 23, 2005
Chico, California
Like the title says...So i was wondering if this would cause any problems suspension wise or anything else? I noticed when my friend pulled his gs-t up next to mine. His is all stock and i thought he had lowered it because mine looked further off the ground than his...LOL
are you talking about wit stock rims also, or aftermarket because theres a lot of different things that will evaulate this, when i tried this on my stock rims i put bigger in the back, i think it was 215/45/16 and the stock 205/45/16 i believe it had poor handling and the car felt like it wanted to slide off the rode when i turned hard, so i ditched that set up and just put the bigger size of the back tires all the way around and have it lowered 2in . Oh anbd i forgot the handling sucked with that bigger in back set up dispite that i have front and rear strut bar, so i wouldnt recommend it unless its aftermarket rims. I have a friend with 225/40/16 in the back on his stock rims and the regular size tires on front and his looks mean as hell sitting like that, but i dont think it did any justice for his handling either. that set up is more for drag racing but if you like slamming corners i wouldnt recommend it
I suppose I should have ellaborated on my answer. The question is NO you will not "hurt anything" by running a staggered wheel setup. Do you want to? depends on the situation like the above poster mentioned.
I just think it doesnt look as good...I like how my friends looks with tires of the same size
Its aftermarket rims too by the way. I think im going to get tires of the same size and see if it looks better. I hope it does.
If you have ABS, it would not funtional correctly when any one of wheels is not the same as others. :dsm:
that could be true... You could risk it if you really like the way it looks that way but i know you wouldnt want to go back and forth spending money trying to figure out which size is the best size so i guess just keep doing your research.
I must not have ABS then because it works right now and ive got different size tires on. I think im going to get smaller tires for my rear so it looks lower and much better IMO.
ya u should get new tires in the back.. the whole bigger back tire setup looks wird when the front of your car is goin downward.. i bet ## friends car looks way tighter :p :p JK
Well, you only use ABS when you brake hard enough to lock up the brakes then the computer takes over. So in normal driving, yeah your car "works".
