zippyshoe
- 440
- 18
- Aug 10, 2005
New Holland,
Pennsylvania
My car has been idling poorly for the past few days. Today, it threw two CEL's - I pulled the codes, which both turned out to be P0170 (Fuel Trim Malfunction) using my pocketlogger. Did some research and found that this is often caused by a faulty front O2 sensor. I took a look at my O2 voltage with the car idling, and found that it is sitting at a constant 0.04V (instead of bouncing between 0 and 1 volt). I also noticed that my Long Term Fuel Trim is at +12%. Based on all of this, I believe that my O2 sensor is faulty. I was wondering if I could drive my car for a couple of days until I get a new O2 sensor without causing any great harm to my car (other than getting lousy gas mileage)? Thanks for any input.
