eldiabloz13
- 612
- 8
- Mar 2, 2005
Fairhaven,
Massachusetts
-What is the HP of a 420a.
-Now if you were to take a stock Gs-t turbo kit and put it on it at 8 psi(knowing your engine can handle 8 off the start) what would be the HP then.
-Now also if you do the internals on the 420a and use the same stock kit.
-What could be the highest psi you can reach now.
-Also the highest HP you could get from that stock kit.
There should be 5 numbers at the end if your going to answer the whole question. If you only know one part of each then thats fine.Thanks a bunch guys
