Please Support Rix Racing
Flywheel resurfaced , still has small cracks ?
gravityforce
235
Jul 10, 2002
Avondale, Arizona
I just got my stock flywheel turned and it still has some hairline heat cracks. The guy who did it said that the cracks dont go all the way threw and it should be fine, he also said something about magnaflux that he did to it. I just need some input on this , is the flywheel still good to use ? and what is magnaflux ? Thanks ahead.
Oh, Magnaflux is used to detect flaws in ferrous parts. (metals)
Magnaflux is a proprietary process of dusting a ferrous metal with iron oxide powder (or powder suspended in a fluid such as kerosene), inducing a magnetic field into the item, and looking for the dust to form "lines" which will form along surface and sub-surface cracks. I was certified for it a few jobs ago. Largest thing I was ever in on was the crank on a Norwegian grain ship- 3' bore, 6' stroke, 18" con rod big end diameter. We used an arc welder to create the field.
For nonferrous materials, Zyglow is a similar method for surface cracks. Then there's eddy current testing, and dye-penetrant, X-ray and ultrasonic.
That's insane. When the hell is ACT going to start selling their flywheels for the DSM? That crap scares me.
Think of your flywheel like the windshield in your car. When you get a crack in it, and it's fairly cold out, you turn on your heater. As it warms up, you can watch the crack get bigger. Then after a week/month the crack reaches the outside of the windshield and stops. Just think what the flywheel's gonna do at 6500 RPM's when those cracks get bad enoughOMG Just a thought though.
