View Single Post
Old 05-10-2003, 03:43 PM   #45 (permalink)
mavisky
mavisky's Avatar
Region: Midwest
Classifieds Rating: (0)
Re: mixed up transmissions
Quote:
Originally posted by 16GTSI
mavisky hoping you canhelp me out......I am taking the turbo engine out of a 93 and putting into my 90 nt. Because the nt was fwd it cant accpet the full awd system off of the turbo car. I also cant run the nt tranny because the turbo isa 7 bolt and the nt is a 6. My question is, can i run the awd tranny exclusively fwd by leaving off the rest of the system and transfer case and not experience any power loss? Or is some of the power always transfered to the rear wheels(non-existing in this case)?
you can use the awd transmission. the thing is you'll have to pull the transfercase output shaft out, weld up the hole for it, weld up the center diff on the awd tranny and use the awd axles. ( not so bad since you'd have equal length half-shafts then).
or you could simply hunt down the nt 7 bolt flywheel and use it since the only real difference between flywheels of the same model is the amount of mounting bolt holes.
if you get the nt flywheel expect to shell out around 200 for the new flywheel and about 300 for the nt clutch. or you could shell out around 800 and keep the awd flywheel and clutch, and do the modifications to the awd tranny to make it work in a fwd manner.
____________________________
-Kyle Mavis
#97 Street Modified Fort Wayne SCCA
Offline
[webpage] [posts] [gallery] [blogs] Reply With Quote
Sponsored Links
