I bought a turbo car from Wisconsin and swapped the engines and got everything I needed from the donor car. Here is another picture. Fuel cut pressure solenoid is the only circuit I can think of to add. Funny you should mention the resistor pack. I haven't added it in yet. I have cut it out. I was going to mount it in the stock location. There is a hole already on the firewall. I think I grounded the knock sensor to a bolt nearby on the block.
