60mm throttle body will flow more than enough air for a n/t. sink your money into something that will give you a good upgrade.
what are your mods so far. id at least have a full exhaust system, intake, k&n spark plug wires and other bolt on stuff before worring about the throttle body.
the only way youll need a bigger throttle body is a crazy head build up with like 2mm oversized valves in it, or a real high compression ratio
