daltah
- 516
- 1
- Sep 27, 2002
phoenix,
Arizona
Is their a difference between a 2g automatic and manual axles and differential?If so what is different?
Note: This feature currently requires accessing the site using the built-in Safari browser.
The axles are the same but the ring and pinion gear ratios are different. You can't use an automatic gear in a 5-speed and vice versa.Is their a difference between a 2g automatic and manual axles and differential?If so what is different?
