Need new engine please help
[H]
Aug 29, 2002
OK, I am a new member so let me tell you about my car....
I have a 92' Elcipse 2.0 16-valve DOHC...
Right now its sitting in my driveway, drivable but only on tree cylinders, I think I burned the engine out...
Anyways I am considering of buying a new engine... Here is my delema....
I want to buy the turbo engine, will and what problems will I run into installing this engine, and what else do I need...
Do I nee a new?
ECU
Electirical Wiring
and anything else...
Also I was thinking of getting an engine of a GSX, also getting a GSX tranny and drivetrain, will I have any problems putting these into my car or not...
Also do any of you know where can I get these parts and how reliable these places are and what price range I am looking at for the parts...
Thank You
Any help is appreciated...
As far as I know,the turbo engines motor mounts are in different places than the non turbo.What you might want to do is spend the money on rebuilding the non turbo and then get a turbo kit for it.
If you are going to get a GSX engine and drivetrain, why don't you judt buy the GSX and save yourself a whole lotta work tryin to swap all the stuff. Sell your car and sink that money into the GSX if you are planning to do what you want to.
I am not flaming you, I drive a NT also ( turboed ), but it seems like you are trying to create yourself a lot of work. Good luck
Actually, i think the motor mounts are in the same places on a 1g. Just stick with the turbo engine swap for now. you will need pretty much everything from the turbo model including ECU, fuel pump, injectors, you need to run a knock sensor somehow (not sure), etc....
don't mess with the drive train stuff unless you have a LOT of time, money, and experience, if you really want AWD then just buy a gsx or tsi AWD.
Thanks guys,
Yeah I'll probably end up getting a turbo engine, or maybe build up my current engine and put on a turbo kit later....
The reason is I am building this car up for autocrossing... That is the main reason I wanted the GSX.....
I have a few grand that will go into the eninge, but buying a used GSX is out of the question...
