4g63 NT Intake
92MitsEclipseGS
Aug 2, 2003
Ok Ive been looking for the answere to the answere of this question for a long while. Ive got 92 eclipse gs, 4g63 nt, i put an aluminum intake pipe on but i had to bolt up the big ass stock filter and all to my pipe. because of the MAS, what can i do to the MAS to be able to put a normal cone filter on?:confused:
the best thing for you will be K&N filter. u can practicly get it at any auto parts store. it will be a cone style filter, that will hook up to your MAF sensor.
here is application search link
http://www.knfilterchargers.com/search/appsearch.aspx
it will look something like this
but if you want to use a regular cone filter, you will need to replace your MAF with a different kind of MAF, like GM. which will cost you some $$$$
or you can use your imagination and create some kind of can, that you can fit on the MAF, can that will have a piece of pipe where you can attach the filter.
something like this or this
but, do some research, and you will find more answers.
hope it helps,
Denis
