Need Help ASAP!!! Please
EklipzGS
Oct 30, 2003
i just installed a k&n filter today and i was havin any problems at all, about 3 hours later i go out to start up the car and it idle between 1/2 and 0 and then cut off, the coolant light came on, ok i check that and was low filled it up thinkin the problem was solved, but when i started the car up it did it again, ok next i unplugged the o2 sensor and it idle normally, did i do somethin wrong when i installed the filter?
It's probably unrelated. An air filter is one of the few DSM mods that CAN'T give you trouble. Sorry bud, but that's all I got.
are you sure you plugged back in the mas ????haha ive forgotten too a few timesOMG .....other than that i don't know what it could be...
sounds like you forgot to plug your mass back in i did that two weeks ago when i put a new radiator. had to take out my intake. it was still a tight fit.
