Intake Question PLEASE HELP
ShugNite318
Aug 18, 2003
i recently bought an intake off of ebay, and it didnt come with a mas air flow sensor adapter to hoook up to the intake pipe, does anyone know where i can buy these?? any help owuld be apreciated...thanks mike
I would think it would come with one. Check ebay and see if they sell them seperately. Check through our sponsor section some of them carry stock parts or might be able to hook you up with something like that.
-mike:talon:
Since you're a 98 and n/t meaning you have the 420A then there is no mass air sensor. The intake is just a filter connected to a pipe which goes directly to the throttle body. There is a nipple for the breather hose which connects from the valve cover to the intake pipping.
he is right, the 420a has no mass air sensor, all you need is the rubber hose which goes from the first pipe to the top of the valve cover. the bottom pipe should have a place to insert an air breather in case the filter ever becomes submerged under water
