1996Eclipse420a
- 162
- 1
- Jan 12, 2012
Wilkesboro,
North_Carolina
I picked up a used 2000 neon transmission. My 5th gear went out and would not stay in gear at all. I use atf-4....
Now the gears are taller in the neon transmission if I'm correct. My question is, is it a noticeable difference in torque? I running 15lbs of boost.
Second do I keep my speed sensor and gear from my old transmission or do I leave the neon speed sensor in the transmission? I don't want my speedometer to be off.
Ooops I just realized I posted this in the wrong forum. I apologize
Never mind. I've figured out everything I needed to know except one thing. The motor mount that bolts on the gear box side of the transmission... can those be swapped out with the N/T Eclipse one? Because the 2000 Neon one is completely different.
