dsmwv
- Nov 11, 2012
Elizabeth,
West Virginia
I've searched around and I can't really find help with this issue. My 98 GS wouldn't even idle correctly a few days ago. It would start and die not even 2 seconds later. I ended up removing the exhaust because the only way it would stay started is when I would detach the exhaust from the headers. When I removed the exhaust, I found the o2 sensor was just covered in black. It needs a new head gasket and there's a coolant leak. So, could the o2 sensor make it run like crap? or could it be out of time? I know the obvious head gasket and coolant leak but could that make it misfire/backfire while driving? I've only drove it maybe 20 feet and it started misfiring/backfiring. I would like to fix it because I'm really attached to this car.
I really appreciate it, thanks.
