SM90
- Apr 12, 2013
Lancaster,
Pennsylvania
Hey Guys,
New to the forums and really in need of some help. My girlfriends 98 GS blew the head gasket a while ago and we finally go around to replacing it. I ordered the following;
Gates Timing Belt Kit ( Belt, water pump, idler pulleys)
Top end gasket kit with the MLS head gasket
New Plunger Tensioner
New Head Bolts
Anyway I have a good bit of mechanical experience but pretty much all 2 stroke engines ( dirt bikes & snowmobiles) and push rod V8s, never did a DOHC motor before. I got the top end apart and head pulled fairly quick and easy, cleaned everything, reassembled and I'm currently at getting the timing belt properly set.
Now, before removing the belt as I did my tear down, I set my crank pulley at exactly TDC, crank pulley mark and the one on the block were perfectly aligned. My cams however were like this (timing marks were close but) the intake cam was slightly above parallel to the head, and the exhaust cam was slightly below parallel to the head. The were say just shy of a tooth apart.
So I set my cam pulleys perfectly aligned, crank pulley 1/2 tooth BTDC and put the belt on, torqued the plunger tensioner, pin slid in and out perfectly, and turned the motor over twice, with no interference.
When I stop with the crank pulley timing marks perfectly aligned, my cam marks were off, almost exactly as much, (maybe just a little bit more) then they were before I pulled the original belt.
I have read 20-30 links about timing these motors, and ive seen several times people say the marks never align perfectly.
Here is a picture of how my cams currently sit, you can see the marks are about a tooth out, and this looks exactly how it was when I started. Is this way to far off, am I right, what do you think???
Thanks for the help, I really need to get this car back on the road asap as we are sharing my car, and I want to just get this thing finished, I got laid off from my job Monday as well so its been a rough week, hoping to finish so I can drink a few this weekend.
New Head Bolts
