Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 420A DSM Tech > 420A Bolt-on Tech
420A Bolt-on Tech Intake, exhaust, ignition, fuel system, cooling, etc - specific to 2G N/T DSMs. New Members must limit their 420A tech posts to this forum.
Reply
LinkBack Thread Tools
Old 07-26-2008, 04:38 PM   #1 (permalink)
Proven Member
Region: Eastern Canada
Classifieds Rating: (1)
Reputation: talonation777 is more helpful than not
2gnt Cooling fan issues..PLEASE HELP
Alright, here goes..
I purchased a rad and fan combo (which I'm sure most of you have read from my other posts). I'm having a hell of a time hooking this stupid fan up and getting it to run. I'm going to list the things I've done in point form. If anyone can make some suggestions as to what I should try next, don't hesitate to respond.
This is what I have done so far:
1. Hooked the SPAL fan up to the passengers side harness. Fan did not come on when operating temps were reached.
2. Hooked the fan up to the drivers side harness. Fan still did not come on when operating temps were reached.
3. While fan was plugged into drivers side, I turned on my AC, the fan came on! I plugged it into the passengers side, and turned on my AC, the fan came on again!
At this point I thought that maybe the ECT was messed up and wasn't sending a signal to the ECU to turn the fan on. I can't test the ECT because I don't have my voltmeter.
4. I replaced the ECT with a spare one that came on my t-stat housing. Put the new ECT in, plugged the fan into the driver's side and waited for my car to reach operating temps. Still the fan did not come on!
To recap, I changed my ECT. Tried the fan on both harnesses (driver and pass). The fan comes on when the AC is turned on, but not when operating temps are reached (180-200 deg.)
The only other thing I can think of is perhaps a bad relay..but the fan worked when the AC was one so wouldn't that eliminate that??
I'm going to get a new voltmeter and check the ECT, or just buy a new one.
If anyone can help me, that would be great. I want my car back on the road, I've already missed out on half of the summer, I'm hoping to catch the tail end of it.
Thanks in advance guys, sorry for the long read.
Offline
[posts] Reply With Quote
Related 420A Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
2gnt Cooling fan issues..PLEASE HELP talonation777 Newbie Forum 1 07-28-2008 01:46 AM
SPAL fan wiring...2gnt HELP!! talonation777 420A Bolt-on Tech 27 07-26-2008 11:24 PM
Does A/C fan NOT help with cooling? SnowBird Newbie Forum 4 04-17-2007 03:48 PM
cooling fan always on!!!! help please vkalloo Newbie Forum 2 09-26-2004 08:02 PM
cooling fan problems 92fwdtsi Newbie Forum 2 12-16-2002 09:54 AM
Page generated in 0.09873891 seconds (68.19% PHP - 31.81% MySQL) with 10 queries
