only 2 injectors firing, need help asap!
i got good compression, got spark on all 4 ( verified by timing light) and i only get injectors 1 and 3 firing ( i pulled the fuel rail and turned it over and saw those firing), if i swap the connectors from 1,3 to 2,4....the others will fire....so i know all injectors work.... what the hell is my problem...ive gotta get this car running!
____________________________
BERNHARD
