Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 420A DSM Tech > 420A Bolt-on Tech
420A Bolt-on Tech Intake, exhaust, ignition, fuel system, cooling, etc - specific to 2G N/T DSMs. New Members must limit their 420A tech posts to this forum.
Reply
LinkBack Thread Tools
Old 05-28-2008, 09:12 AM   #1 (permalink)
New Member/Lurker
Region: Midwest
Classifieds Rating: (0)
Reputation: Beppe is an unknown
Timing Pulley
Hey guys i have a quick question. as far as the timing pulley goes. not the balancer pulley. the one that belt rides on itself on the crank. i replaced the crankshaft seal. now i pushed the pulley back on. does it go on till it cant go no more. or does it need some space? because it looks very close. thanks in advance!
Offline
[posts] Reply With Quote
Related 420A Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Timing tensioner pulley moves? vexixx Cylinder Head & Short Block 7 12-07-2006 12:42 PM
crank pulley timing mkspriggs Bolt-on Tech 3 11-29-2005 03:29 PM
Setting Base Timing With Aftermarket Under Drive Pulley? Timing Light? gsxstac Tuning & Engine Management 3 02-09-2004 10:35 PM
Timing Belt Pulley ? Sartuche24 Newbie Forum 3 11-21-2003 12:48 AM
Crank Shaft pulley loose, not attached, timing belt fell of of crank shaft pulley BacknBlack92ESi Problem Diagnosis 14 11-13-2003 06:36 PM
Page generated in 0.08029008 seconds (62.22% PHP - 37.78% MySQL) with 10 queries
