SpyderX
- Dec 26, 2002
Ok, I have a 97 Spyder GS-T. Recently I put on an Apexi downpipe and N1 Exhaust. Then, today, I installed the APexi upper intercooler piping kit and twin chamber blow off valve. After the install, everything worked good for like 20 minutes, then after driving, something started to go wrong. Right off the line everything would be fine, as RPMs increased, so did the boost on the boost guage. It keeps increasing untill it gets all the way to the top, where it stays, a moment or two before it reaches the top, it feels as if the turbo isn't producing power. At some points, it seems as if the car will stall. Keep in mind, before the install, everything worked fine. The guy at the shop said it could be some sort of leak in the piping, after checking the clamps and stuff, everything was tight. The only thing I can think of is this....the new pipe that connects to the intercooler itself, is bigger then the pipe coming off the intercooler. There is such a difference that the pipe from the intercooler can fit completely inside the new pipe. I did connect it though, and there is the silicone hose and clamps on both pipes, and they are as tight as possible. This is the only thing I can think of. Unless it has something to do with the fact that the BOV vents to the atmosphere, unlike the original, and I need an AFC. If you have ideas please post or e-mail me. [email protected]
-Scott
-Scott
