HELP!!! Spark plug wire problem?
GsT916
49
Sep 8, 2002
This may sound careless... but I just got magnecor 8.5mm wires and I just installed them. But, the problem is that my engine is SHAKING like crazy?!?! Then, I thought OK ...Installed wrong so I just play around with the wires and same problem. Directions in the box was no help and car manual said nothing about that?
I try to put in my stock wires, but they don't seem right to me and I forgot which wires go in where.
I think it goes in 4- 1- 2 -3 from left to right? Did I install it correctly in the engine. The coilpack need help too. Two questions being asked:
1) Why the shaking?
2) Correct procedure in the enigine and coil pack?
I apologize for an easy fix.
i believe it goes 4-3-2-1 from left to right one being next to the timing belt cover. i hope this helps but if the shaking just started thats probably your problem
the motor, if you are standing in front of the car, 4-3-2-1, the coil pack, is starting on valve cover side, 4-1-2-3,
