Mistaspakles
- 227
- May 17, 2002
I'm debating whether or not to get rid of my Green for something smaller. I'm debating this because my car is a street car and I never go over 18psi. Am I wasting the potential of my Green by not going over 18psi? On pump gas and 18psi, I was only able to make 310whp. Would I have better results with a different turbo at 18psi and pump? If so, which should be my turbo of choice?
K&N, DSM-Performance intake pipe, FP Green, Big Greddy FMIC, UIP/Greddy Type-S, 60mm TB Elbow, 1G TB, 1G Intake Mani, 1G Head, ARP Head Studs, 1G Rods, ARP Rod Bolts, Polyurethane Motor Mounts, Magencor 8.5mm wires, Denso 660 injectors, Web Cams 546/547, Quaife LSD, RPS Stage 2 Clutch, Ported Exh mani, AHP O2 w/Tial 40mm WG dump to atm, RRE DP, Apexi N1 Exhaust, Walbro 255LPH, Apexi S-AFC, MBC, B&M Short Shifter, Greddy EGT/Boost Gauge
