cleaning
- Mar 4, 2003
MarylandUS
I also own a na eagle talon and was trying for find out some other information on my other car and thought that you guys might be able to help me.
The problem is that I need bigger injectors on my Saab. This though is not an easy task for the budget tuner. I have gotten this far so far and thought that you might be able to fill in the rest. The ford injectors work on the car and from my understanding will also work on "some" dsm's. The injectors on the car are of low impedence. The stock injector specs are listed below if this informatin is to any help.
Type
Bosch EV1-3E, Red 4-hole
Resistance/Temperature
12.0 +/- 0.35 ohms at 20 deg C
Flow Capacity
176 +/- 14 mL
Note: Per 30 sec.
I want to upgrade the injectors to the dsm 450cc injectors. Again I understand that this not a true dsm tuner question but thought that you might be able to help out another dsm owner.
Thanks in advance for any help that one may be able to lend here.
Type
Flow Capacity
176 +/- 14 mL
Note: Per 30 sec.
