Star Turbo question
kagegod
217
Feb 22, 2003
I've looked at some pics of the t3/t4 turbo that comes with the star kit and oddly enough, mine doesn't seem to look right. With the turbine housing bolted to the manifol, the outlet on the compressor side points up in the front. From the pics I've seen, it looks like this is supposed to point down. Am I seeing things? :confused:
Are you at a stage 1 or a stage 2? You can undo the bolts on the compressor side and move the housing to point it down. If you are at stage 1 it needs to be point'd up because stage 1 dosen't include an intercooler, so the pipe runs straight from the compressor to the TB. Stage 2 runs from the compressor to the FMIC, that's why it's point'd down!
