do i need a fpr?
droptopgst
270
Oct 1, 2002
Myrtle Beach, South Carolina
I just bought a TDO5 18gand they sent me a 255lph fuel pump. do i just install this and everything will be good or will I need to run a fpr? Is there a way I can tell by driving my car if I will need one or not. Will this work alright without the rewire for the time being? thanks for any info and thanks for the turbo turbochargers.com it looks nice cant wait to run it tomorrow.
The turbo will just bolt on, you really need to install the pump at the same time as the turbo. As far as the fpr that depends on if you have upgraded injectors. i recommend running 550s with that setup. you should have no problems with base fuel pressure, 550 's s-afc tuned and a 255, that should be good fro 12's with the right weather conditions and race gas.
(i have 550s if you need them)
BT
