oil in intake pipe and turbo
greyGS-T
I'm in the process of putting a B16G on a @G and when I took off the intake pipe I noticed oil sitting in the pipe and a little sitting on the inlet of the turbo. I assume this is coming from the tube that runs from the valve cover to the intake. Is this a bad thing to have happening? By the way I bought the K&N filter to eliminate this in the future. Any help would be appreciated. Please dont flame or make fun of me for this I know it might be a well known thing for some but not all.
Thanks guys. I figured it was harmless but I thought I would ask anyway. I bought just the K&N filter to keep it from happening anymore.
Matt
Here's an even better solution that's practically free-- just unplug the breather hose from the intake and plug the intake. Just let the hose hang down toward the ground. You could get a longer hose if you want, to make sure it gets all the way past the engine so any oil doesn't blow all over the place.
if you're so concerned about the oil, get a lil catch can and hook it up to the oil line after you disconnect it. make it chrome and get rice points
