Output shaft seal leaking
G50trim92
40
3
May 8, 2002
Coralville, Iowa
After I installed my act 2600 and spool center diff I noticed a leak in my tranny. I pulled the T-case off and the output shaft seal was leaking tranny oil! My ? is do I have to pull the tranny out again to put in the new seal, or is it possible to do it with the tranny in the car yet? I have a shaft puller and driver if that matters.
Any insight would be appreciated,
Thanks!
So I can change the seal with the opening provided by removing the
t-case?
I have the exact same problem. So I pulled the T/C and output shaft, but I'm having problems installing the new seal, due to the very limited space. Does anyone, who has done this before with the tramny in the car, have any tips?
It's been a long time since I've done it but if I remember correctly I used a big socket that fit on the out side edge of the seal. Then tap it with a rubber hammer.
