everyone that has gone turbo how much hp do you have now
daltah
516
Sep 27, 2002
phoenix, Arizona
how much do you have know and how much did you have before going turbo?how much hp at the wheels and the crank
i would estimate around 150 hp at the flywheel nt, now i'd estimate 275-300 depending on boost.
here's the power mods.
Engine-90 tsi awd engine w/ 92 filter housing,tb, coil pack, and cam sensor
K&N filter
Ported big 16g
Ported 1g o2 housing
Vizzion Power Systems 2 1/2" intake pipe
Vizzion Power Systems mbc @ 19psi
Custom 2 1/2" upper intercooler pipe
1g nt throttle body rebuilt and powdercoated
HKS super sequential blow-off valve vented to atmosphere (flame on )
Accel 300+ Thundersport wires
NGK 7es's
Buschur 2 1/2 downpipe
Buschur 2 1/2 test pipe
Pacesetter 2 1/2 catback w/ 5" tip
3000 GT VR-4 fuel pump
Captain Clutch 5 puck disk with high pressure plate
Phantom Grip limited slip insert
Removed A/C and everything associated with it
Autometer pro comp boost
Autometer pro comp electric oil pressure
Autometer sport comp egt guage w/ tre k-type probe
Carbon Trix 3 guage pod
S-afc
it ran a 14.02 @ 104.7 on only 16 psi of boost and a huge pre-turbo leak that meant i didn't get full boost til over 5500 rpm. :(
