jdmawd
Banned Member
- 3,318
- Mar 20, 2002
GreenBelt,
Should the clutch master, and slave cylinder be replaced when installing a heavier clutch? They both have 120K on them
Originally posted by LethalEagle
I just rebuilt both of mine..... It was a lot less expensive. It depends on if you have good cylinder walls or not.
Originally posted by rdrkt
Tym at Buschur said it wasnt necessary when I asked him the same question the last time I got a 2600 from him.
Originally posted by MuttedTSiAWD
Most people end up having to rebuild or replace master or slave cylinder so just be ready for it
Later,
Originally posted by jdmawd
yeah i heard the same thing,however i have also heard of people blowing the slave or master shortly after the install. im trying to avoid a problem to come.
so it would make sense to just replace them now right? i replaced the master on my 96 max back in the day. so i guess it cant be to much different
i dont know s**t about trannies
but the master cyl and slave cyl just make it a "power clutch", dont they? if they do, than cant you just eliminate them and make it a "manual clutch", yes of course it would be quite a bit of pedal pressure, and uncomfortable to drive, but could you do it?
