DSMpilot
- Jan 29, 2003
what are the advantages and disadvantages of putting a turbo in to a non turbo?
Originally posted by mdre21
crankwalk is only about 9%-10%. Both engines are good and the 420A seems to be responding to boost well, so i would say if you already have a 420A turbo it but if you are looking to buy a car I would buy the 4g63.
You are full of crap!!! for the same money it would cost you to switch to a gst, you could bolt a turbo kit on your car and already be a little faster than the stock gst.Originally posted by qwall
it's gonna cost you a lot more in the long run to put a turbo in than buy a factory turbocharged car........you'll be only able to run so much psi unless you redo your bottom end ( more money)
q
Take into consideration how many people bought the 4G63 (gst/gsx) and then get that number. Once you get that number divide it by how many cases you know have crankwalk or have had it. Then add about 10k-30 thousand people and divide that number by the total number of people that bought those cars...It's not 10%, it's more like past 60%!!!
so Kirby, if he slaps a factory turbo on a non turbo car then he'll be faster than a gsx right
the last official numbers I saw on crank walk were something like this:
95-9%
96-9%
97-17%
98-9%
99-9%
even without the number of actual vehicles sold if you set all five years equal in numbers sold that averages out to be 10.6%, now i don't remember if those were exact numbers but it was pretty close.
Originally posted by silvereclipse
I disagree, Buy a turbo kit for about $2500 and some supporting mods for ~$500(dont even NEED many) then you dont have to pay insurance on the turbo, that is the main reason i didnt get a GS-T
Yeah spin a rod bearing and then have your crank walk and tell me wich one is worse....Originally posted by mdre21
just a quick note, any motor can suffer from crankwalk, some are just more suseceptable than others, I'm pretty sure my brother's 4g64 engine in his galant did, from what he was telling me and miatas crankwalk a lot more than dsms do, and 420A's could crankwalk too. 420A's tend to spin rod bearings instead and that sucks just as much if not more.
Plus there is usually one thing that causes spun bearings in the 420a...oil strvation, very easy to avoid.
