Jhoe
- 90
- 1
- Aug 18, 2002
St. Louis,
Missouri
My (nothing much) mods... Ported 2g o2, ported 2g exhaust mani, walbro 255 fp, 2.5" downpipe, high flow cat, and muffler, running 18lbs boost still rich, a/f guage, exhaust temp, boost guage...
The ACT 2600 has been called a tranny breaker...will it cause harm if you let the clutch out slowly and not drop it out? Clutch just went out and I am looking at a ACT 2100 and the 2600...I wanna put more power eventually but not for a while most likely...I obviously dont want to destroy my transmission but if I go with a 2100 and i drive my car hard just about all the time...will it wear out rather quickly or will the 2600 do the same when I am letting the clutch out slowly rather than dropping it out...
Basically my question if i slip the 2600 out will it do transmission damage and will it last longer than the 2100....
thank you
thank you
! No, I meant physically dropping the tranny to change the clutch. Meaning, the 2100 will be useless when you go to a bigger turbo and trying for 1.6 60ft times.
So get the 2600 now and save the hassle of swapping clutches out later.
