dsm-onster
DSM Wiseman
- 8,592
- 130
- Jul 11, 2004
Bloxom,
Virginia
I have three questions. . .
I will be sticking with my 4G63 block.
1. Since there have been rumors of 4G64 crank walk, is crank walk a bloc issue or a crank issue... If I put a 64 crank in my 6bolt block will I have increased my chances of crank walk?
2. I know a longer rod yields a better r/s ratio and consequently an engine better suited for higher rpms. Will a set of long rods make a substancial difference for engine life and/or reving performance?
3. Does the crank have to be modified to clear the oil squirtes? Forced Performance sells a new 100mm crank and it is mentioned that they "clearance" the crank for the oil squirters... I'd rather keep the squirters. Does a JY crank have to be modified then to work in my block?
My final upgrade will be a SMIM. This is why I am wondering about question #2.
Thanx
Thanx
, its dangerous and unresponsible). If your car doesnt see track time all the time then I'm more than positve that revving to the 9k wont blow your car up that second.
