Fuel pressure guage install
TSIAWDTalon
384
15
Jun 21, 2002
Greensburg, Kentucky
I got a liquid filled Pro Comp from a friend. Where would you guys suggest tapping into to get a good reading? Should I just tee off the fuel line before the regulator? Sorry for the noob question...
I had my fuel rail drilled and a bung welded on top. Then I tapped the bung and attached the gauge right there. It looks really cool but can only be done without a strut tower brace.
I want to measure the fuel pressure with this gauge before it reaches the regulator. I think I am going to tap into the line as it feeds the fuel rail. Then later when I get an adjustable fuel pressure regulator, I want to put a little gauge on the rail itself. This way I can monitor what is coming from the pump, and what is at the rail.
