larsrya8
- 509
- 21
- Mar 9, 2005
Menomonee Falls,
Wisconsin
Just finished installed my Walbro 255HP fuel pump. Install went well, didn't break any fittings or anything. I used DSMLink to turn the pump on with the engine off to check the fuel pressure.. everything seemed fine. Then I started the car.
Fuel pressure was sitting at about 62 psi. I panicked. So I turned the car off and hooked up the battery charger to get some better voltage with the engine off. Now the fuel pressure sits at 55 psi. I turned the adjustment screw all the way out, and the pressure stayed at 55 psi. I unbolted the AFPR from the brake fluid resevior and moved it around to make sure the rubber return line wasn't kinking; pressure stayed at 55 psi. I removed my gas cap; pressure stayed at 55 psi.
Other details: My gas tank is reading 1/8th full because I didn't want any gas spilling into the car. The pressure gauge seems to be working fine; it will read 0 psi after I turn off the pump with the adjustment screw completely out. The AFPR was working just fine with the stock pump. If I turn the screw in I can get the fuel pressure to climb to 70+ psi (without leaks too). The Import Evolution FPR kit also uses the stock rubber line that attached to the stock FPR... could this be the problem? Also, the fuel pump is not rewired.
The three things I can think of are:
1. My return line is kinked/dented somewhere under the car. It was cold, and I didn't feel like jacking it back up to check, so I just went inside and had some hot soup.
2. There is some sort of blockage in the return line. How would I go about finding or fixing a blockage?
3. Somehow... I haven't thought of anything yet... I managed to do something to the return line while installing the new pump. Maybe something on the assembly inside the tank, or maybe to the rubber or hardline connected to the assembly.
Has anyone else had this happen by simply changing the pump... with an AFPR installed? My fuel pressure at idle is worse than what most people have when still using the stock FPR. I'm fairly sure my pressure regulator is not at fault, because it was working fine beforehand, but I won't rule it out completely.
I plan on checking on the return hardline underneath the car tomorrow, but if anyone has any other ideas/experiences to share, I'd love to hear them.
