selmerguy
- 1,811
- 23
- Nov 14, 2004
Killeen,
Texas
I started my ms install today and just did some basic stuff. Here are some pics of what I have done. Keep in mind that I am doing this install with the intent of being able to go bact to the stock ecu with ease. I didn't want to drill and tap anything.
I started by installing the 2 sensors that you must use with Ms(Intake temp and water temp). I teed the water temp with little trouble. I think that being teed wont effect the temp readings too much. For the intake temp sensor I wanted to make sure it got good flow. What I did was unscrewed the three prong tap for the vacuum and put the new sensor there. I then took out the stock intake temp sensor and made a tee for that and the vacuum port. I figure that after I have the ms running fuel and spark the stocker wont be doing much. Even if it does it will get close to perfect readings anyway. Then I loomed up my ms harness and fed it through the stearing column gromet. I installed the power with a 20 amp fuse to one of the wires for the isd relay. I installed the ground to the factory ground.
Then I had to install the lines for the new afpr that should have came yesterday.(damn ups)
This was not to much trouble and is pretty selfexplanitory. I was hoping that the fittings for the stock fuel filter assymbly were npt. But alas they wernt so I had to do the ruber hose with hose clamps trick. Had to delete the pics for my write up.
