Ja17Bmx
- 91
- Oct 16, 2004
Doylestown,
Ohio
Alright well I have been boosted for over a month now with no problems at all. Just yesterday I removed the egr valve and replaced it with a block off kit. Now My car will run fine until the ecu tries to activate the egr and the car will run like crap. The vacum will drop to 10, the car wont keep an idle and will back fire. I dont know if this problem is due to the egr being gone, because this never happened before. I did a compression test and everything is the same as when I started the kit. 200 across the board. Is there anything, like a resistor or something I can plug into the egr electronics to trick the ecu into thinking its still there and working, so this wont happen? Or do I have a more serious problem on my hands.
