For future reference:
If you are using MMCD 1.8G, You need to go to: Options> Preference>
Once you are in preference, You will see a the word
EGRT next to it you can choose what value you are going to input. values like: 3.0 Bar, 2.5Bar, 2.0Bar, WBO2, EGRT & 0-5V.
Then all you need to do is Hook up the wire into the EGRT place. (I Think this is for Federal cars only, because CAlifornia cars may fail Emission :blahblah: )
NEW Problem...
I Finally got a WIDEBAND from PLX.....
I am using
MMCD tool to download the logging. But, My problem is that it keep showing up as a EGR-TEMPERATURE instead of 0-5V from the wideband, Does any body has a Formula to convert it back to 0-5V or to AFR?
In my datalogger is in AFR or 0-5V, it is the mmcd Tool that keep converting it back to EGRT
TIA
