View Single Post
Old 01-21-2006, 01:56 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
DGajre777 Offline
DSM Wiseman
DGajre777's Avatar
Tech Posts: 2,807
Classifieds Rating: 17
PRofec Type-S
As easy to use as a manual boost controller, but with advanced electronic boost controller response & consistency, the PRofec Type-S keeps things simple. Based on the ever-popular Original PRofec B-Spec, the Type-S has two rotary switches to select two independent boost setting (a Lo. and a Hi.), while another "Gain" switch compensates the wastegate’s valve response. Now, matched with a quick acting, large capacity inline control solenoid, the Type-S can increase boost as high as 3.0kg/cm2 (42.66psi) and it works with both integral and external wastegate set-ups, while still being compatible with our Remote Switching System or SCC & adapter.
Sounds good. Don't you have other performance mods to do before spending $400+ on an dual stage electronic boost controller? I would understand if you were FWD and you need low boost at launch and high boost later, but if your sole purpose for having hi-low settings is to drive on the street and race on the track, why not just keep the boost controller you have now? I'm sorry, but it doesn't make sense (to me) to spend $400 for the Type S. If your current setup is running fine, why change it?
Visit DGajre777's homepage!
