running consistant 12's
brandons 95
95
2
Jan 13, 2006
deltona, Florida
ok right now i have
injen intake with k&n filter
dejon tool upper intercooler pipes
greddy type rs blow off valve
apexi front mount intercooler 2.25 in pipe on turbo side and 2.5 in on intake side
evo3 16g turbo
evo3 o2 housing
apex 3 inch down pipe no cat
dnp race exhaust manifold
my goal is 400awd hp and i am wondering what mods i should do next to get me to that goal the fastest and cheapest, also what clutch is good to use with awd with out worrying about crank walk
Cams, Smim, Bigger turbo......
I like my SBR 3500 clutch. But if i get another clutch i will go with a ACT 2900 with a organic disk
a 255 fuel pump, and some 650's , and a SAFC, but if you plan on running 400 whp a new 60-1 turbo or a 50 trim, but i doubt a 16g will make 400 whp, so just start with the first 3 :thumb:
If it were me.
255lph wahlboro
adj frp
injectors
maft
gm mas
dsmlink
Install all of this then tune it. Once you max it out change turbos. I'm not sure if the 16g will flow enough air to get 400awhp consistantly but I may be wrong. Thats just my opinion. The act2100 seems to be the clutch most reccommend for a 2g to stay away from crankwalk.
what about cam gears and undrive pulleys is it worth what you get or not, i am going to do the hks 272 cams and the hks valve springs for sure though
there is only one upper intercooler pipe, there is also a lower intercooler pipe, so maybe thats what you mean by pipeS.
i think hes asking what he needs to have a soild 12 second car.
your going to need a new exhaust, i would look for a supra smic, an evo III 16g with some 650cc injectors and an afcII, a 190lph warblo or a 3000gt vr4 pump or an evo8 pump, some 7's (ngk plugs, one heat range colder, dont know the exact part number),
look here, this might not work for you, but it did for this guy.
http://dsmtuners.com/forums/showthread.php?t=60008&highlight=quater+mile+exhaust+pump
edit: ok so you completely changed your first post, nvm, basically dont listen to anything i said...
