johnwohl
- Jun 22, 2005
Fargo,
North Dakota
Hi all. I started boost leak testing today at the throttle body elbow and I'm already having troubles. It seems I can only hold about 3-5 psi!
I verified that my tester assembly is airtight and it is not leaking at the throttle body elbow. I am using the tester from boostpro.net to do the testing. I am using a pretty good electric compressor to provide the air. I shut my engine off normally and it is not TDC if that matters.
I found that I was getting quite a bit of air coming out of my valve cover vent so i capped that off. The first problem I ran into was obvious. The throttle body gaskets (elbow to tb and tb to intake mani) were leaking so I replaced those. Great, those no longer leak.
Now though I can still only hold about 3-5 psi. I can't hear any air escaping anywhere. I listened to the exhaust pipe too and can't hear any noise.
I checked my PCV valve and it rattles around good and I can barely eek out a little air through it blowing as hard as I can, I didn't use the compressor because I didn't know if I would break it or something. I did go to advance auto and get some new pcv valves (3 actually) but they were all pretty pathetic and I could blow quite a bit though them.
I am wondering now if the pcv valve might be the problem and how I could verify that. Maybe also a valve is open or something letting air escape? I don't know and I'm finding this frustrating. On another note, the car feels fine and pulls ok but I do spike a bit. Any ideas are appreciated. I tried to proofread but the spellcheck doesn't work on my browser for some reason so please excuse any errors.
