IA97GST
- 81
- Nov 26, 2005
Ida Grove,
Iowa
Hi Guys, Im New to the website... I recently found out about dsmtuners.com.. Ive been a Dsm.org guy for quite some time but that sites died down so much it seems... Ive had three 1st Gens 1n/a (probably the best 1st car a 16year old could want) and 2 TSI. Recently upgraded and got myself a 97 Eclipse GST...... Got Traction? I know thatll be prob.
neways.. the car had a bad head and when i tore into it i found out that the urbo was junk as there were shavings in the dump tube and the oil pan.. Bearings chewed up a lil.... I wanted build a 6 bolt... but this motor only had 15k on the motor.. and found out that it had been built with eagle rods and weisco pistons... and the crank is std.
so this is what i had refreshed on the motor..
hot tanked the motor...
new .40 over rings on the weisco pistons...
new Clevite Race mains and rods bearings
Balance shaft removal (had already been done)
new oil pump as the turbo caused old one lock up pretty much and jump my timing.
New Rebuilt Head
Im planning on a evo 3 turbo ( nothing but good ive read on this turbo)
I wanna know what my motor should be capable of with 550cc injectors and this turbo and also installation on my arp head bolts that im reusing? Your input be greatly appreciated. Thanks, Ia97gst (Larry)
neways.. the car had a bad head and when i tore into it i found out that the urbo was junk as there were shavings in the dump tube and the oil pan.. Bearings chewed up a lil.... I wanted build a 6 bolt... but this motor only had 15k on the motor.. and found out that it had been built with eagle rods and weisco pistons... and the crank is std.so this is what i had refreshed on the motor..
New Rebuilt Head
