tstkl
- 3,889
- 74
- Feb 10, 2005
SoCal,
California
OK, so i recently replaced the following with the parts listed:
oem intake manifold gasket, dejon tool sheet metal intake manifold, oem throttle body gaskets, dejon tool upper intercooler pipe (short route with gm maf), used gm maf, maft, johnny racecar front mount intercooler, dejon tool 2.25 inch lower intercooler pipe, dejon tool j pipe (1.75-2.25), dejon tool intake pipe, k&n airfilter, some off brand air filter for the positive crankcase ventelation thingy (the intake manifold is still hooked up to it, i did it correctly)
what happens? when starting the car normally: she gets to about 800 rpms and then dies as fast as possible. when starting the car at about 35% tps: if she makes it to about 3k shes fine, but if i let go of the gas she dies fast. while looking at the logs for this, it would appear that the rpms start to drop DRASTICALLY around 2500, so im assuming that above 2500 shes fine, and that seems to be true.
what have i tried? in short everything. old 1g maf, even worse.... pressure test, cant hold any psi at all. so its a vacume leak, right? so i take some carb cleaner, have someone keep her at 3k, and start spraying to find out where... nothing... when i cleaned the throttle body with this stuff, and i tried to start it, it went up to 3k by itself... then died... so i know this stuff will change the rpm if its in the intake.
i smell fuel... BOY do i smell fuel... badly...
the other day i checked the spark plugs, they are practically brand new, it looked a little darkish and had some oil on it, im assuming thats from the top tho, because earlier in this cars life (about 1k miles ago) it had an oil cap leak that got oil all over the valve cover, so im assuming its from that... didnt have time to check any other cylinders tho, just #4...
ANY IDEAS? any at all will be greatly appreciated....i PROMISED myself i would finish my car this 9 day weekend, and its almost over with no luck, (although im almost done with everything else i wanted to do, so maybe ill just give up and take it somewhere once im done...satan....
