someguyjon
- Mar 7, 2005
Cary,
North Carolina
First of all, I searched for about an hour to find an answer to my problem, and I found bits and pieces, but not really what I'm looking for.
I bought a 96 GST back in march with 38k miles on it. It was running fine, no problems. Around May, my clutch pedal started squeaking. It got worse, until I finally had the the bushing in the clutch pedal replaced about 2 weeks ago. When I picked up my car, the pedal was very tight to the top, there was no play at all. Over the course of 2 weeks, the pedal "loosened" and there was probably the right amount of play in it. Yesterday though, my clutch started slipping in 4th gear when i downshifted going up a hill.
I took it back to the garage, and I'm assuming they adjusted the master cylinder (based on what I read) all the way out because the mechanic said he couldn't adjust it anymore than he did. The pedal disengages the clutch now about halfway down. It is still slipping in third and fourth gears when my turbo kicks in.
The clutch feels really strong in first and second gear. The mechanic said he put the e-brake on and dragged the back wheels in first gear.
Could this be anything other than a worn out clutch? I read a post about oil being slung onto the clutch because "the output shaft to the transfer case seal in the bell housing went bad". It only has less than 50k miles on it!
ANY IDEAS!?
Also, if a new clutch is in order, should I get factory stock? Or something else? My mechanic told me a new clutch would be $600 to $800. Help a newbie out! Thanks.
ANY IDEAS!?
