topnotchgsx
- 104
- 1
- Nov 4, 2004
Warrior,
Alabama
Well after debating on dsmlink or AEM EMS, I have decided that while I have the money that I am gonna go balls out and get the AEM system. My question is that if I go ahead and get this, will I be able to install it on my car while it is stock? The only mod that I have done so far is a K&N filter. In the next week or 2 I will have a 3" exhaust, fuel pump, and FMIC. But even then, will the base map on the AEM unit be as good as the on programmed on the factory ecu, or I am gonna have to go and get it tuned. B/C if that is the case then I will wait til I get some more modifications done before I install it. Also what else am I gonna need to run the AEM unit. Like I know I will need a 3-bar map sensor, and probably a wide-band O2. But do I HAVE to have that stuff RIGHT NOW or can it wait a little bit? And one more question. With the AEM unit, I will be able to do away with the MAF garbage right? Or will that come when I get a MAP sensor? I think thats all I needed to know for now. Thanks in advance for any help!
-Keylan-
-Keylan-
