RWKustoms
- 795
- 5
- Jun 5, 2005
New York,
New York
Ok, not new to this site but this is my first post after doing a good search that didn't give me any answers and has not solved my problem.
I have a problem with my Eclipse NT/AUTO..When I'm driving and I come to a complete stop (stoplights,stop signs,traffic etc.) the rpm drops to about 500 RPM like it's about to shut off and then goes back up immediately to 900 RPM and the car idles fine..This only happens when I come to a complete stop while driving but other than that it idles fine..I read posts in regards to idle/RPM issues not the same as mine and got a little info and so I changed my coil pack, plug wires and spark plugs..Got a MSD coil w/ round terminals and MSD super Conductor 8.5mm wires and NGK plugs..My car still does the same thing after I installed all these parts ($150)..Can anybody tell what else might be causing this issue?
I would like to get this figured out ASAP.
.what i do now instead is when the car starts to idle ### at stop i just turn on my fans and the bad idle goes away..this will do till i can fabricate a better heat shield some how
..hope this helps
i guess ill just have to get raped and pay some shop to look at it.
..overcooks the acid inside your battery,and sprays all under your hood.
