dsmtrance
- 438
- 1
- Mar 26, 2002
Savannah,
Georgia
91 AWD. Buschur stage 3 bottom end and Buschur stage 3 top end (verified to have both). Approx. 5k miles on motor. I've only owned the car for 2-3 months and have put only about 500 miles on it. VPC/GCC setup. Cosmo pump. 550cc injs. SX Regulator. TMO stage 3 chipped ECU. MSD Ignition. 7es plugs at .032. Car is knocking like crazy on the logger. At idle and at speed. No matter what, as soon as I give the car ANY throttle it goes full knock. It's KILLING my power. Only getting like 7-9 deg. timing at WOT.
Messing with fuel does nothing. Pulled spark plug wires one at a time and problem is there regardless. If you listen closely at idle when you rev it up it sounds like there is almost like a soft "hollow" knock sound coming from the motor. It follows the rpm too it seems. Under accel. it's not heard. I put in brand new JAM lifters and that did nothing either. Everything in the head looked GREAT when I pulled the cover too. Anyone that can throw out some ideas it'd be much appreciated. Not 100% sure where to go with this one next.
