im a dumbass
greentat
Apr 25, 2005
lumberton, Texas
well i installed my safc2 buti didnt have the safc2 harness plugged to the unit i went inside to get the operating manual but i came outside and found out my brother had already started the car before i could set it up and is was running like shit, well it can still crank and run but it studders when i press the gas does anyone know what happend :confused:
check your settings on the s-afc II..put all of them to 0..i would just take off the negative terminal on the battery for about a min to reset the ecu than i would start the car bck up
i did that it still ran ruff yesterday and today it wont even start but it sounds like it wonts to :(
sounds like a wire isnt connected properly, but first make sure you set the afc to karman, and make sure the acc arrow points up.
Is your profile updated? If so, what is the purpose of the safc? I suggest removing it and see what happens.
