View Single Post
Old 09-12-2005, 09:00 PM   #93 (permalink)
na90dsm
Proven Member
Classifieds Rating: (3)
Reputation: na90dsm is an unknown
Quote:
Originally Posted by anubis
this is a long post, but i'm looking for some accurate, solid information and advice.
i've been on the forums for quite some time during the past few days trying to soak up as much information as possible about this topic. i have decided that i want to do something like this with my non-turbo laser. i haven't found anything about this except on this forum. i tried posting in a forum talking about stroking with a turbo and didn't get much help. so i'm reposting here because i think it would be more appreciated by my non-turbocharged peers.
for now, i am SERIOUSLY considering doing this. i believe i have most of the supporting mods or will have them soon and my engine is out of the car, in pieces, and ready to be built.
let me begin with my parts list.
what i have:
k&n filter, hacked maf, solid intake pipe
ngk irridium plugs, 10mm wires
full 2.5" exhaust system with header and cat eliminated
underdriven pulleys and aluminum crank pulley
adjustable cam gears
turbo cams
what's on the way:
stage 1 port/polish head
balance shaft eliminator kit
ported intake
want to port the header to match the new port job
what i will get:
stock turbo injectors (i believe i need a resistor pack from the turbo too)
stock turbo fuel pump
fuel pressure regulator
high flow fuel rail
safc2 and pocketlogger stuff
what i need to stroke:
6bolt crank
some block work
pistons
i don't want to do a bottom end swap. i'm familiar with the 4g63 engine and have all ready spent a lot of money on parts for it. now for the questions:
what else would i need for the stroker kit?
what other supporting modifications would i need to do to make this work if any besides those listed?
which crank should i get?
what is a recommended compression ratio?
what pistons should i get (with CR in mind)?
will my ecu suffice?
keep in mind, i do not have any plans to turbo charge this car and do not want to, and cost is a factor in this project. i welcome and appreciate any answers, suggestions, and advice. if you have constructive criticism or civilized discouragement, i will welcome that too.
thanks in advance.
pm me about this or my post will be 4 times as long
Offline
[posts] Reply With Quote
Sponsored Links
