Kevin Doe
- 78
- May 13, 2003
Cincinnati,
Ohio
I'm wiring up my water injection kit. Its activated by a boost switch. When boost hits the set level, it basically completes the circuit to the pump relay. I could hook this up to any +12V source, and it would work fine.
But, I would like to hook it up to a source that only has +12V when the car is actually running. Not when the car is off, or even in the on position. I want there to be zero possibility that the water injection can be triggered, unless the fuel pump is also running, and boost pressure is at the triggered value.
So, my question is what ECU pin, or what wire should I tap into. I think pin number 13 looks like the best candidate, but not too sure. I know I want to hook into one of the factory fuel pump relays wires, and I don't care if its the trigger wire, or the fuel pump output wire (because I've rewired my pump and added my own relay, so basically the factory relay triggers, then that output triggers my relay).
Is pin 13 the best source of this? Or is there another wire going to the gold box near the ecu under the radio that would be better? Can you give me a wire desctiption too (color and striping please).
Thanks,
Kevin
Thanks,
Kevin
