Some injectors are high resistance (non-turbo injectors) and some injectors are low resistance (turbo injectors). Unless you use the resistor pack or some type of resistor the Low resistance injectors will be getting to much resistance and then, well you can figure the rest out. Just you have to have it, or some type of resister to lower the resistance to the injectors.
I hope that didn't confuse you.
